Stroker Build Q?!
  • darvo
    • Dec 2010
    • 407
    Stroker Build Q?!
    I currently have 2 engines an early eta 2.7 engine and an 88+ Is engine. I'm making a stroker with these.
    My question is which one is cheaper to rebuild?
    Should I use the 2.7 crank,rods and pistons in the Is block or should I use the Is head, Im,wiring and ecu in the Eta block?
    *This is for a turbo build, arp studs,rod bolts(if necessary) and cometic HG will be used.*
    • 37828
    The blocks are the same, it makes no difference which one you use.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • acolella76
      • 2950
      Some say that the crankcase in the 2.7 blocks is cast differently due to the larger crank, but I can't really confirm if this is true or not. I doubt it though.
      Yeah, it really doesn't matter which block you use. Are you doing a full rebuild with new bearings and bolts?
      -Alex
      • darvo
        • Dec 2010
        • 407
        yes full rebuild.
        • acolella76
          • 2950
          In that case, make sure you buy bearings specific to the date of your block. There was a changeover between early and late model blocks.
          -Alex
            • 34836
            the only difference are early/late blocks which use slightly different bearings.
            • russhixmo
              • Jun 2011
              • 336
              I've helped out at my local shop and built a 2.7 stroker and seen what they can do an for what it is it's actually kinda impressive, especially to boost, I've got lots of motor parts if you need any as well.
