what could have happened?
  • Madinthe717
    • Aug 2011
    • 172
    Ok so here is what i have done since my 30 was last running. I wanted to pull the fuel pump and the level sender to see why my gauge wasnt working, when i realized, the sender was like nothing ive ever seen before. so I put everything back in and connected everything as it was before. i go to start my car fires up and dies in a matter of seconds. so i thought because i took off the line coming from the fuel pump that i would keep it running with ether so fuel would get back to the rail. well it ran off ether then nothing. i checked the fuse checked the relays i have no clue. i took the fpr off the rail and it has fuel in there. I dont know what else to do or check.
  • Blackangusinc
    • Jul 2010
    • 244
    I recommend going over the harness connections again. Your pump isn't pumping and the pump/sender assembly was the only thing you touched before the issue started.
    971-295-7077
    91' 318i
    • Madinthe717
      • Aug 2011
      • 172
      the car ran 2 days before i touched the fuel pump
      • Madinthe717
        • Aug 2011
        • 172
        I had the car running then fixed and oil leak and tried to see what was up with the pump and then no start issue. I know it has spark because it runs off of ether
        • paperplane94
          • Jul 2011
          • 420
          Did you switch the feed and return lines?
            Given what you've done, tee a gauge into the rail supply line and see what the pressure is when the engine is cranking. I suspect the pump isn't running or the rail pressure is too low (bad pump or bad FPR). You can't get the hoses to the pump wrong, but the power connections to the pump could be a problem.
            It would be a help to know what car you have as the fuel and gauge system varies by model and production date.
            • Madinthe717
              • Aug 2011
              • 172
              I have an 89 325i. There is one line comming from the pump and I know the plug for the pump is getting power I don't have a multimeter to see how much though.
                How did you check for power to the pump if you don't have a meter? A test light means, well, pretty much nothing.
                • Madinthe717
                  • Aug 2011
                  • 172
                  That's how...
