I have a 1990 325i completely stock (AKA not my sig), it is the winter car hence stock. This winter the car started out running fine however starting earlier this week I have been running into a fairly serious issue. I will paint the picture,
cruising down the road all seems normal then randomly while under slight or heavy load the car will start bucking. Sometimes it is very slight while other times it will make your head smash off the steering wheel. While it is bucking, if you push the clutch in and attempt to rev it up it will usually not go past 3000 RPM. This tends to happen more at higher rpms like highway driving, but it does happen around town.
To answer the usual "Did you fuck with something?" No, I have not done anything to the car besides put gas in it and check the tire pressures for the past 3 weeks.
Any help appreciated,
Car addict
Car addict
