stock eta low boost turbo, can it be done ?
  • expressfish
    • May 2008
    • 526
    Got to thinking the other day, if my truck (cummins diesel) is equipped with a turbo, why cant I turbo my eta in just plain stock form ? I mean, my diesel has a low rev limit just like the eta. Could I just turbo it, no fancy gauges, computers or all that crap, just a stock turbo set up, can it be done ? Im really considering a set up once I get the car painted but something more or less maintenance free, just a boosted daily driver. I know the stock valve springs and the stock head dont breath well blah blah blah, so those comments wont help. If the only way it can be done is by swapping all the intake stuff from an "i" model then so it be, just wondering if it can be done with a stock configuration. See ya in the morning !!!
    [sigpic
  • acolella76
    • 2950
    Sure you CAN turbo it. It's just not the best for high HP performance. Go ahead and boost it!
    -Alex
    • devon.818
      • Feb 2011
      • 2937
      yeah at like 4-5psi lol.
      or! just get a RRFR and some larger injectors and a turbo chip from ebay or TCD.
      hell, just do all ebay stuff, if you want it cheap and dont really care.
        • 37829
        The whole point of the Eta is how reliable and economic it is.
        Boosting it is like trying to turn a 3 legged horse in to a race winner.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • 603Racing
          • Dec 2010
          • 612
          Even at 0 psi you will see increased peak power with a turbo, but 4~5 psi is pretty safe. If you're only looking for mild gains then it will work. A chip is probably the most cost effective and reliable method.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
          • nebulous123
            • Jun 2011
            • 923
            since when is a 3 legged horse reliable and economic?
            '84 325e - "Elizabeth"
            '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
            • Insane E30
              • 71
              this, i was thinking it also...if i wanted reliable i wouldn't ride a 3 legged horse
              1985 325e - a cheap work in progress
              http://myquest4happiness.blogspot.com/
              • andrewm
                • 456
                I could see it being economic....after all, it does only have 3 legs
                1987 Delphin 325e Sedan - Natalie
                1990 325i 24v
                1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                • acolella76
                  • 2950
                  I paid no mind at first.. but now that i think about it... what happened to that 4th leg? Did it just fall off? Doesn't seem very reliable if so. Also now the work on each leg has increased by about 9% so it's not as economic as a 4 legged horse. If it were 1876 and I was looking for a horse I would buy one with as many legs as possible, wouldn't you? Get a horse with 12 legs and you have plenty to spare and the work is shared evenly.
                  There, now the problem is solved.
                  -Alex
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Even cheap turbo setups require almost all the parts of a large turbo setup.
                    Do it but!
                    Don't run a RRFPR
                    Get a real tune
                    Get an intercooler
                    Do the math to figure out the perfect efficiency for your engine and choose wisely. It would be a TORQUE monster. Run a longer rear end gear to make up the difference. It would awesome!
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • TobyB
                      • 5250
                      Sure- if you size the turbo to start boosting early (2k or so) you'll actually see plenty
                      of extra torque.
                      5 psi would be a 33+% gain- far more than a chip alone. And you can skip the
                      intercooler if you want.
                      Plus, you'd have fun doing it.
                      Why not? It'd be unique, certainly...
                      t
                      • rodpaine
                        • 33
                        A D'Sylva ECU chip and a 3.46 Diff will provide a good performance increase for not much money. But, the engine and electricals have to be in very good condition, if not perfect. I've personally seen too many etas that have not had really decent maintenance, that owners throw performance parts at and wind up with a half baked performance configuration... a waste of money.
                        FWIW,
                        -Rod
                        Rod's 528e support web site
                        A car can be restored many times. It is original only once.
                        • Stephen
                          Шлем ишака
                          • 10774
                          The biggest drawback i see, is if you're not power hungry, a headswap would likely be easier and cheaper, and a big bump in power without having to worry too much about reliability or economy. With mine i got up to 29mpg on a roadtrip with a 2.93.
                          • expressfish
                            • May 2008
                            • 526
                            head swap with all the extras or head alone ?
                            [sigpic
                            • pandaboo911
                              • 2070
                              You still need a manifold, custom exhaust, oil lines, tap the pan..etc. You can do without an IC. There are better mods out there for that amount of money.
