rods
  • backwoodsE30
    • 122
    rods
    One of the techs at VAC wants me to use 135mm rods apposed to the 130mm rods that I have. His reasoning is that a 2 valve head takes longer to fill so it should remain near and at TDC for as long as possible.
    Here's the run down, VAC stage 3 head with 288/272 cam, hone extruded intake manifold, #19 injectors, miller psik and war chip, full header back, custom CP 10.8:1 85mm pistons, M52 crank. What should I do?
    alcoholics do it till you barf
  • CarsSuck
    • Oct 2005
    • 968
    If you're using custom pistons, its a no brainer, use the longer rod. It's a more ideal ratio, futhermore, it's the length bmw has used in the m20b25, m52, s50 and s52. The only reason people use eta rods in their 2.7/2.8 strokers is because they're cheap.
    --Will
    • backwoodsE30
      • 122
      ok thanks for the input. 135mm it is
      • Cinnabar325is
        • 1064
        That's quite a motor, do the 85mm pistons make it a 2.9? And is CP a brand? Where did you have the intake manifold extrude honed and what did it cost if you don't mind saying?
        '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
        • backwoodsE30
          • 122
          Yeah it will be a 2.9l. CP is a brand that VAC carries. IE did the manifold $600 I think
          • TobyB
            • 5240
            Smokey Yunik agreed- stuff the longest rod in there that you can without
            compromising ring seal....
            Free torque, no real drawbacks...
            t
