Bad throttle position sensor???
  • 89 e30
    • 249
    Could a bad tps cause slow acceleration and low idle or is there something else that is causing my problem?
    BIMMER für IMMER
  • dnguyen1963
    • Nov 2011
    • 2651
    Vacuum leak can be notorious.
    • 89 e30
      • 249
      I already replaced all the vacuum hoses
      BIMMER für IMMER
        That means, well, essentially nothing. There are far more places to have intake leaks that the few hoses that connect to the intake. Have a shop run a smoke test on the intake and fix the leaks it reveals. Also check the operation of the TPS and replace it if either the idle or WOT switch aren't working. Oh yeah, if it has 100k on it, replace the O2 sensor.
        • 89 e30
          • 249
          smoke test has been done and o2 sensor is new, cleaned icv, replaced coolant sensor so I'm guessing tbs is bad
          BIMMER für IMMER
