just got done looking at the head...everything looked good with the valve cover off. No cracks or obviously broken parts anywhere and I looked over everything 6 or 7 times to make sure I wasn't missing anything. Your guess is as good if not better than mine at this point. Piston ring or valve guide? Just a random bad backfire due to too much oil? It had literally 2-3 mm over the full line on the dipstick after I fixed the leak...
M20 went boom
Did you pull the plugs to look at them?
I have never had a back fire on my stock ECU or my MS..https://www.forabodiesonly.com/mopar...re-irs.356333/
Originally posted by MonkeyMadness View PostDid you pull the plugs to look at them?
So after making some amazing scrambled eggs with pepper jack cheese melted into it and cayenne pepper on top, i went downstairs and looked at the plugs. As i was unplugging the boots, starting at cyl 1, i noticed cyl 6 was unplugged. I'm thinking...WTF?? Maybe the backfire blew that off and thats why it ran rough...
nope...as i was putting the spark plug tool down there and let it spin a couple times...i realize there was NO SPARK PLUG. when i did my tbelt that one wouldn't tighten all the way. either that or i was so tired i just didnt go far enough. so it must have backed up and with a little too much oil the backfire probably caused it to shoot out causing an immediate vacuum leak and the engine only running on 5 cylinders. so i put one of my spare spark plugs ( i always buy extras ) in and it runs better than it did before. amazing....thanks guys. sorry for the ordeal...
