so last night i left my apartment to run an errand and out of nowhere...BOOM. Sounded like a tire exploded or something of the like. So i immediately looked at my gauges and saw the RPMs were getting below 500 so I shut off the engine and coasted to the 4 way stop i was approaching. and i probably shouldnt have done this but i decided to start it back up to try and get around the corner and then i shut it off as soon as i turned and coasted to a parking lot. but when i turned it back on..it started fine and ran, but it was rough. so i parked and immediately wondered about the new timing belt i put on a month ago. i pulled that little black plastic back cover off and broke it to pull it out. the belt had tension with just a little play and didn't appear to have snapped from what i could see with that limited space. i know for a fact when i did my belt everything was perfectly in time, the belt had good tension, new tensionor pulley and spring etc. I went the whole 9 yards with this tbelt replacement because i was originally considering replacing my head gasket for the heck of it. and then a couple weeks after doing the timing belt and thermostat (water pump is fairly new), i replaced the oil filter housing seals and stopped my oil leak. ever since the oil leak was fixed it started making a weird noise like a muffled sewing machine. and before i replaced the thermostat, the old one was causing it to overcool to the extent that in the winter, it wouldnt get out of the blue. ive also recently replaced my cat and all sort of ignition and seals. The one thing i havent done lately is adjust my valves. If you guys have any clue what this may be let me know. i'm gonna start tearing the engine apart this weekend and double check the timing belt and valves before i try to rotate the engine by hand.
Sorry for the long post...figured some background might help
