86E to I wiring help
  • cowden_12
    • 354
    I have an 86e chassis with an i harness and brain etc. What color wires do i need to connect together to get the tach to work since the connectors and wire colors are different?
    If your harness was from a 9/87 or later 325i/is/ic the tach and econometer signals are routed through C101, which is how the later cars are wired. Cars up to 8/87 have a connector off the engine harness near the DME connector for those signals. To make the tach work you'll have to modify the harness to extract those signals. See http://wedophones.com/BMWManualsLead.htm for the diagram for the harness you have to find the wires to pick off.
    • TG Goose
      • Jul 2011
      • 234
      I'm doing this exact same thing. It would be nice if there was a sticky of some sort, or someone could explain what to do in better terms. Pictures go a LONG way, some of us are visual learners!
      ______________________________________
      1984 LSB 318i - Sold
      1986 325i - Motor Swapped Track Car Project
      1995 318ti - Sold
      1999 540iA - Daily Driver
      • TobyB
        • 5298
        ha- I gotta do this sooner than later, too.
        t
        • diggity_1031
          • Dec 2010
          • 33
          I did the same to my car. If you search the threads around for that swap, some dude did an excellent write up. I went from 85e to 89i and it all works perfect.
          found it. this is the same write up I used and its perfectly written and works great
          http://www.r3vlimited.com/board/showthread.php?t=100939&highlight=c101[/URL]
          • TG Goose
            • Jul 2011
            • 234
            I found some better info from this site, and it has pictures!
            1995 318ti - Sold
