project v3.0
  • backwoodsE30
    • 122
    project v3.0
    After several changes in my plan I have landed on a 3.0l stroker. I bought #19lb injectors when I was going to do a smaller build, will they work with the 3.0l or do I need bigger ones?
    alcoholics do it till you barf
  • e30trooper
    • 11576
    dude you need 42# for a 3.O stroker
      • 37828
      Are you planning to run it on stock Motronic? Miller? Megasquirt?
      You need to post more info.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • backwoodsE30
        • 122
        Sorry. VAC stage 3 head, schrick 288/272 cam, hone extruded intake manifold, miller psik -w- war chip full header back. S50 crank, 135mm rods 86mm pistons, adjustable fpr. I think that is the important stuff.
        • backwoodsE30
          • 122
          i need to know what injectors to run with all that noise.
          • CarsSuck
            • Oct 2005
            • 968
            c'mon man, do a build thread and take some pictures. We all want to see the goodies. That's probably why you're gettin no play, here.
            I *think* 19lbs will be enough. That is in between an M50 (17.5 lbs) and the s52 (21.5 lbs) sized injectors. The M20 fuel system runs a lower pressure though, so it'll be a bit less. HTH
            --Will
              • 34839
              run the 19# at 3.5 bar, they'll be fine.
              • CarsSuck
                • Oct 2005
                • 968
                can you really just up the fuel pressure like that, with no ill effects?
                --Will
                • backwoodsE30
                  • 122
                  I could take pictures and post em up. But we all know what a greasy old block looks like and everything else I have is boxed up patiently waiting
