Need Help Now
  • bowtie2bimmer
    • 830
    The pelican parts article is just how to replace it, i know there is a way to test two pins for resistance...
    1987 BMW 325ic - Emma
    • akorcovelos
      • Dec 2006
      • 1149
      Copied from another forum:
      A proper resistance measurement is done power off. Based on your resistance readings, the CPS is defective.
      I have a good, later-M20 salvage yard CPS to work with. Terminal 1 is on the side leading out to the metal sensor. Mine had 549 ohms between 1 and 2, and infinite resistance between 1-3 and 2-3.
      For people new to digital multimeters, infinite resistance may display as 1 or OL (out of limits).
      2012 MCSCC/NSSCC CP class champ
      HSAX Instructor
      • paperplane94
        • Jul 2011
        • 420
        from e34 bentley:
        • bowtie2bimmer
          • 830
          So testing the outside plug under the "pac man plug", the male side (pins) none of them came out anywhere close to 540. From what I believe is 1 & 2 i got 110ish while set on the 200k setting. tested a buddies and his came out to 571 on the 2000 setting..
          So from what i infer mines at 110000 ohms???
          • akorcovelos
            • Dec 2006
            • 1149
            There are two identical plugs that share a bracket under the diagnostic port, make sure you are testing the plug that goes to the cps. If you are and those are the readings your getting the cps is bad.
            HSAX Instructor
            • bowtie2bimmer
              • 830
              Judging by this pic i found from an article on e30 tech
              That's the one i pulled and tested
              • bowtie2bimmer
                • 830
                So on that note? Who has a known working CPS that I cam buy? Looking to get soon so will pay for expedited shipping
                • FLG
                  • Sep 2011
                  • 3165
                  You need to test the other end of that plug...just slide it out of the metal holder that side your testing goes to the dme
                  Sent from my Galaxy Nexus using Tapatalk
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • bowtie2bimmer
                    • 830
                    no, i tested the male end, the one that goes to the plug...
