what can cause a no crank?
  • bastianshaw
    • Jan 2007
    • 2210
    besides the starter?
    battery is good
  • EThirty318i
    • Dec 2010
    • 219
    no fuel or spark.
    • Dj Buttchug
      • Jun 2010
      • 7686
      bad ground.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • SpecM
        • Oct 2005
        • 4531
        Originally posted by EThirty318i
        no fuel or spark.
        he said "no crank"
        battery, starter, ignition switch, or ground issue
        1989 cirrisblau-metallic 325i
        • bastianshaw
          • Jan 2007
          • 2210
          CPS will crank just not start?
          • bastianshaw
            • Jan 2007
            • 2210
            looks like im down to ignition switch or bad (main?) ground
            • ttrousdell
              • Nov 2009
              • 1770
              If cps is bad it will crank. no fuel or spark though
              Test resistance from engine to strut tower
              The Build:
              • nebulous123
                • Jun 2011
                • 923
                no motor
                '84 325e - "Elizabeth"
                '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                • paperplane94
                  • Jul 2011
                  • 420
                  broken timing belt
                  check for cam movement through oil filler hole while cranking
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    Originally posted by paperplane94
                    broken timing belt
                    checked AFTER I bought the car camshaft mving that was a relief
