What is this noise? Videos attached
  • 5Toes
    • 9836
    I have never been able to hold a camera super still...
    The white smoke you see is not from a blown headgasket. My DME reset and I have m50 injectors, so it was running rich because it forgot the settings. Additionally it was about 34 degrees outside.
    My engine is ...
    I drove it sort of hard, I would bump shift it every other day, but I believe it is just that it has had a hard life and the gas in the oil didn't help
    I have listened to all 12 valves, they all sound about the same and the chh chh chh chh noise can not be heard through the screwdriver
    Buying a stroker to drop in anyways, so just curious what is wrong with mine! lol
  • 110stx
    • Sep 2011
    • 253
    That sounds bad, but not the same as a broken rocker.
    Still, something sounds very very loose or maybe broken.
    Valves been adjusted recently?
    Care to pull the valve cover and check it out???
    d.hitchcock
    STX e30
    No. 10/110 STX: 1989 325i
    DD: 1991 318is slicktop
    SHAZAM, GOMER, LOOK AHEAD.
    • 5Toes
      • 9836
      Just adjusted all the valves a few days ago while it was amking this noise. I adjusted them a little tight, and they are quieter now for sure
      All rockers looked good, no cracks at all.
      • paperplane94
        • Jul 2011
        • 420
        I would do a compression test, IDK if you care enough to do so.
        Then I would check at the fasteners holding the vibration dampener, cam sprocket. I would also look for something in the vicinity of the timing belt thats getting in the way. Also, check the timing reference marks.
        • 5Toes
          • 9836
          Ill do a compression test. But it is coming out anyways, maybe I can fix it off car, but who knows
          • Keith M
            • 2338
            The knocking could be from a bad thrust bearing. Can you isolate where the chi chi chi is coming from? Front/rear/??
