87 2.7i piston choices
  • Varinn
    • 780
    I have a complete m20b25 I'm in the process of rebuilding, I may be getting a free '86 m20b27. Can I use this setup for a 2.7i build?
    Fresh bearings
    Fresh rings
    eta crank
    I rods (or is the e rod setup preferred?)
    I pistons (shaved 2-3mm?)
    Stock bore, already honed
    885 head
    I have access to a lathe, I just need to know if its worth getting the block and doing the stroker rebuild.
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
  • 5Toes
    • 9836
    Shaving the pistons is a big PIA from what I have read. Little info on it, and you actually have to shave them around 6-7mm
    • Varinn
      • 780
      What kind of comp ratio does the eta crank/rod with i pistons result in?
      1990 332i, 4 door
      2017 Mazda CX-5 GT
      • ForcedFirebird
        • Feb 2007
        • 8300
        Very low compression. If you use eta rods/crank and i pistons, the pistons will be below the block deck by 2mm. You need to shave the block to make it work proper.
        john@m20guru.com
        Links:
        • Varinn
          • 780
          Hmmmm, not what I want to get into. I'd prefer stock cam gear and keep the changes internal. What is the difference between the eta crank and m50/m52 crank? I believe I remember seeing this as an option
          1990 332i, 4 door
          2017 Mazda CX-5 GT
