car runs horrible
  • Gordon1987
    • Feb 2011
    • 76
    car runs horrible
    325i computer system. when cold the car runs good but when at operating temperature the car runs rough and bearly idles and sputters while revving out. any thoughts?
  • nebulous123
    • Jun 2011
    • 923
    what motor do you have? if you have an ETA and have an "I" comp that might cause some serious issues.
    '84 325e - "Elizabeth"
    '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
    • Gordon1987
      • Feb 2011
      • 76
      i have the eta block with an I head
      • nebulous123
        • Jun 2011
        • 923
        did you just finish the build or been running it for a while and all of a sudden this started happening?
        • Gordon1987
          • Feb 2011
          • 76
          i have been running the eta computer just put in the I computer and this happen wanted to know if im missing anything im new to the I computer
          • TurboJake
            • 3780
            What all did you swap over to run the I DME?
            Are you running the I or E intake manifold?
            The more descriptive you are with your setup, the more we will be able to help.
            Leave Me Transaction Feedback
            • Gregs///M
              • Mar 2012
              • 2459
              02 sensor. You should have the lambda code 1221 tho. Mine did the exact same thing, runs great at cold but poor idle when fully warm. Replaced o2 sensor and mpg and idle quality back to normal.
              Also vacuum leak might be possible, try a smoke test.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
              • Gordon1987
                • Feb 2011
                • 76
                All I swapped over was the afm, idle control valve, tps, and I'm running the E manifold.. I don't have the o2 sensor
                • TurboJake
                  • 3780
                  You didn't swap the harness?
                  • Gordon1987
                    • Feb 2011
                    • 76
                    Yes I did.
                    • TurboJake
                      • 3780
                      Injectors?
                      • Gordon1987
                        • Feb 2011
                        • 76
                        440 cc I had them on with the E computer untuned and I was able to drive the car fine. Also the car is turbo
