starting problems
  • xikyle
    • May 2011
    • 526
    starting problems
    When i try to start the car, i turn the key. it turns over and over and over, but only starts occasionally on the first turn. i turn the key back 1 and try again, it starts. everytime. why is this? occasionally it takes several pumps of the gas pedal.
    is a coil going out? a fuel pump? A magical curse my old mechanic placed on the car?
    Originally posted by ApexGoblin
    well make sure your priorities are straight... e30 first :up:
  • Kershaw
    • 11822
    replace your fuel pump and your fuel pressure regulator.
    AWD > RWD
    • xikyle
      • May 2011
      • 526
      okay, will do.
      will keep you posted on results of fuel pressure regulator and fuel pump replacement.
      • bowtie2bimmer
        • 830
        I concur with the fuel pump... taking too long to prime
        1987 BMW 325ic - Emma
        • dogsbark26
          • Nov 2008
          • 533
          Wait a minute. Don't just start willy-nilly throwing new parts at it.
          Each of those parts can easily be tested for proper function.
          • xikyle
            • May 2011
            • 526
            how?
              To test the fuel system, tee a gauge into the line that feeds the rail. If the check valve in the pump or the FPR is bad you will see the pressure bleed off the rail pretty quickly after the engine has been shut off. That in and of itself won't necessarily cause hard starts. If the pump & FPR is working correctly and the filter isn't clogged rail pressure will go to normal within a few turns of the engine. But a bad check valve is usually associated with a worn pump that is struggling to produce sufficient flow/pressure. The worn pump & bad check valve will cause starting problems.
              There is a spec in the Bentley for the delivery rate from the FPR, which is a useful diagnostic.
              • xikyle
                • May 2011
                • 526
                still havent replaced either, problem getting worse.
                  • 37828
                  So how about you take the advice given and test the fuel pressure?
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • xikyle
                    • May 2011
                    • 526
                    lol, matt, eventually, i will forgo the tests, and just replace both components saving me time, and money (indirectly) because time is money.
                    • PNWDan
                      • Feb 2011
                      • 1326
                      What was the verdict on your problem?
                      1987 Alpinweiß 325is
                      Like the PNW E30 Local Crew Facebook page
                      • sayed ali
                        • 762
                        When is this happening only when it's hot? / cold?
                        mostly is that your fuel pump is going to die
                        M20B28 Turbo
                        My Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=255839
                        • xikyle
                          • May 2011
                          • 526
                          It kind of took care of itself... Weird
