Cooling system issue
  • StreetMafia21
    • Sep 2011
    • 250
    sup rev ok, so i just recently swapped a 1989 325i motor into my 1987 325i the coolant reserve tank has extra hose that normally leads to water pump however the 1989 water pump has 1 less inlet than the 1987. could i just use a 1987 water pump or will i have to convert the entire cooling system ??
  • 5Toes
    • 9836
    Just go ahead and use the 87's water pump. Totally compatible
      • 37832
      Yes, you need to swap the water pump to the early style.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • StreetMafia21
        • Sep 2011
        • 250
        ok thanx im going to swap it out today
