getrag 240/260 compatability
  • übersteuern
    • 45
    Hi,
    Just curious about gearbox compatability, cos I've heard that the 320i came with a 240.
    Does this mean the 240 can be bolted to any M20? How come an M30 swap only works with a 240 not 260?
    Thanks.
  • tinkwithanr
    • Jun 2010
    • 377
    Because the 320 came with an M10, not an M20. The M30 and M10 have the same trans bolt pattern, the M20 is the same as the newer 24 valve engines.
    Tinker Engineering - 2014
    Mica - 2000 BMW 323i - The one that started it all
    Fiona - 1975 BMW 2002 - The Definition of Project Creep
    Heidi - 1988 BMW M5 - The piece of BMW history
    Silvia - 2013 Subaru WRX - Stock, for now
    • übersteuern
      • 45
      Really, it's an M10?
      I'm pretty sure the 320i is an M20B20?
      • liquidgroove
        • Oct 2007
        • 66
        G240 from M20B20 has same bolt pattern as G260.
        G240 from 318 would have different bolt pattern.
        • übersteuern
          • 45
          Ahhhh...thanks for explaining, liquidgroove.
          • The Humjet
            • Jun 2010
            • 528
            Tinkwithanr you've mistaken the m10 320 from an e21 not e30.
            m10, m30, s14, s38 ect. Have the same bellhousings.
            m42, m20, m50/52/54, s50/52/54 ect. Have the same bellhousings
            • liquidgroove
              • Oct 2007
              • 66
              No problem. I happen to have a M20B20 so i know.. ;)
              • nrubenstein
                • 3148
                Not exactly. The M20 shares the same main bolt and starter pattern as the other motors, but the smaller bolts are not the same. Additionally, the M20 is angled differently.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Correct.
                  Also, the g240 is shorter than the g260.
                  after reading tons of info about the g240/g260 compatibility behind an m42, a friend and I tried bolting a g260 in his 318. After a long weekend of cursing, modifying parts and trying to find a driveshaft, we ended up locating another g240 and leaving the m20 clutch set in it.
                  john@m20guru.com
                  Links:
                  • übersteuern
                    • 45
                    Hmmm... I'm guessing this means that the 320i uses a longer driveshaft than the other M20s.
                    I find it strange that BMW went to the trouble of adapting the G240 just for a single model (320i) rather than just bolting in the G260 like the rest of the M20s.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      They did. Perhaps another D/S from another model fits correct for the g240/m20 combo, bit all the online data/threads said that the m20 D/S worked on an m42/g260 and it had about 1/4" spline engagement vs the normal ~2", the locking nut couldn't even be threaded on properly.
                      john@m20guru.com
                      Links:
                      • The Humjet
                        • Jun 2010
                        • 528
                        Interesting info. And I apologize for my false information given. I'm just gonna nod along with the more experienced members and take their word for it.
                        So I'm kinda confused now. Could you put a g240 from an m42 onto an m20b20? Or do they have their slight differences?
                        • tinkwithanr
                          • Jun 2010
                          • 377
                          My mistake, I was thinking US market only. Thanks for the clarification.
