What kind of hoses/radiator is this?
  • Dsun
    • Jul 2011
    • 371
    So I picked up JasonC's awesome e30
    My buddy and I noticed a difference between the hoses and radiator on other 325i/e and mine
    Here is the hose i am talking about, circled in red:
    and here is a typical 325i radiator/hose combo:
    Anyone know what kind of setup that is?
    Also it looks like the hose balloons when the car is warmed up...im paranoid it could burst.
    What do you guys think?
    Had a smooth purchase transaction with me?
    Please share your feedback
  • Mr. Tasty
    • Jul 2011
    • 3421
    early eta m20b27
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • scottinAZ
      • Dec 2009
      • 1312
      yep, early model cooling system setup. bypass hose is prone to being eaten by the fan, and lower hose is prone to being eaten by the PS belt if the motor mounts are shit
      I saved 15% on my Bimmer parts by switching to ...
      • Dsun
        • Jul 2011
        • 371
        thanks guys!
        Does the early cooling setup not have a fan shroud?
        • Mr. Tasty
          • Jul 2011
          • 3421
          Originally posted by Dsun
          thanks guys!
          mine does.
          (Daily Driver)
          KW V2 Coilovers
          • jeffnhiscars
            • Jun 2011
            • 6010
            thanks guys!
            Without a shroud your fan is sucking a lot of air around the radiator, rather than through it.
            I went through 2 @ of water pumps, tstats & clutch fans trying to solve a cooling problem. The $23 shroud fixed it.
            ...and yes, that bulging hose is at risk
            Alice the Time Capsule
            • dnguyen1963
              • Nov 2011
              • 2649
              if your E30 is an '88 or later, CXRacing sells an alumminum radiator for $169. You can switch everything back to the proper setup for about $250 (hoses, clamps & Shroud).
              • Dsun
                • Jul 2011
                • 371
                Thanks guys, ill be picking up a fan shroud and new hose
                • stamar
                  • Apr 2011
                  • 1362
                  my 89 lower hose was eaten by the ps when the motor mounts went.
                  Just want to change that detail to all m20 e30s I think the lower hose is the same thing. when the pass side mm is seperated and the driver side one is a pivot it clamps it.
                  edit also, even though my upper hose is routed different I would never use a hose that blew up like that it needs to be replaced.
