Hey guys im looking for some help. I have a 325e Seta.
I have been trying a whole bunch of different things and cant figure out the problem. You start the car and it takes about 10 seconds to start. It will sit there and idle just fine but you hit the gas and the idle just bogs and does nothing. But when i floor it it will slowly build up then rev. But nowhere else in the pedal. So i have no throttle response.
Idle control valve is buzzing with key on so im guessing its working.
tps unplugged, idle goes erratic
maf unplugged car dies.
cps replaced from 1988 325is
compression tested fine
timing is tdc. well i believe cam and crank are aligned.
no vacuum leaks.
changed cap, rotor, and plugs
tested another fuel pump from 1988 325is dont know if that one is any better than mine.
bypassed fuel filter to see if it was clogged no help.
sometimes it will backfire out of the intake
sure im missing something i have a mazda b2200 3 seater truck and i have 2 kids i really need my e30 please help me.
no vacuum leaks.
