Fitting earlier in-tank fuel pump to 86
  • Andy348
    • Sep 2009
    • 688
    I just bought an 1987+ fuel in-tank fuel pump instead of the required 86 one for my car. The seller tells me theres a way to make the newer one work (which has less inlets for hosing I believe) yet cannot fully explain it to me due to language differences. The car is currently at my mechanic so I cannot provide pictures.
    I believe he says something to do with connecting two hoses, but I'm not sure.
    You can't make that work without major surgery. You can make the in-tank high pressure pump from a late 318is work as it has both the output and return fittings. But the in-tank high pressure pump from a 9/87 or later 325i/is/ic lacks the return fuel fitting.
    • TobyB
      • 5288
      Yeah, I brazed in a return line...
      ...and that was the easy way.
      t
