E30 Auto Trans Flywheel Order
  • 5Toes
    • 9836
    RealOEM only shows the manual version...
    It seemed to only fit one way, and that was
    spacer
    flywheel
    flex plate
    Is that correct? I have a screeching noise coming from the flex plate area when i crank the engine. The torque and trans are bone dry though, not sure if that could cause a problem like this
  • 5Toes
    • 9836
    I mean crank by hand, havn't blipped starter yet.. battery is charging
      That sounds wrong. I think the order is flywheel, load spreading plate (aka spacer), then flex disk.
      • 5Toes
        • 9836
        I will double check.
        I remember them fitting only one way, and it was either your way or my way.
        • slammin.e28
          שמע ישראל
          • 12054
          The flywheel will have one hole bigger than the other. The plate will not. There is no way for the plate to go on under the flywheel. I just went over this, with a spare block, flywheel, etc with Stonersam.
