Starter Grinding Noise
  • 5Toes
    • 9836
    So I am about to get my motor started and running, however when rotating the engine by hand (or cranking it) there is a terrible metal on metal grinding sound.
    I have the flywheel and torque converter, etc. on the correct way
    When rotating the engine by hand without the starter there are no noises.
    The automatic transmission currently has no fluid (I am filling it up tomorrow with a fresh filter kit)
    When bench testing the starter it operates perfectly fine
    Any ideas??? I am stumped and need my car
  • ohthejosh
    • 4963
    Is it a high screech time grinding sound, If so I have that too but only lasts a few moments. Im thinking its my alternator belt not fully tight. My PS belt was doing the same until I tightened it.
    SO MUCH MORE TO DO!!
    IG: ohthejosh
    LEGIT CHECK ME BRUH
    BUYER FEEDBACK THREAD
    • 5Toes
      • 9836
      No it is metal on metal, coming from that area
      I know it is from the starter because when I rotate the engine by hand with the starter off then it shuts up
      • ohthejosh
        • 4963
        Okay then, I am of no use to you LOL, my knowledge is only limited by my experience. Good luck ;)
        IG: ohthejosh
        LEGIT CHECK ME BRUH
        • 5Toes
          • 9836
          I guess I solved my own problem. I must have put the flywheel back on in the wrong order.. because it is grinding on the starter beforre the starter even kicks out
          Can anybody tell me the correct order for the auto flywheel?
          spacer flywheel torque converter plate or?
          • dreamer420
            • Sep 2009
            • 468
            I forget the order of that stuff, but before I did my 5 speed swap my starter also made loud grinding noises on occasion when starting. it is the the teeth on the starters cog grinding on the cogs of the flywheel. I cannot remember why it was doing it, but that is whats doing it for sure.
            I no longer have this issue with my 5 speed though
            • 5Toes
              • 9836
              Well I might drop the transmission today, but I am fairly sure I have the order correct is
              spacer
              flywheel
              flex plate
              Not an m20 but same thing almost... it is impossible to put the flywheel before the spacer and thus closer to the engine. So I must have done it right, ugh.
              Ill double check today.
              Will this noise go away? I guessed maybe that the flywheel teeth are bone dry and thats why it grinds.. no lube
              • 10Toes
                Me Father Was A Tree
                • Jan 2008
                • 61222
                Are you using the correct starter?
                • 5Toes
                  • 9836
                  Yes. Im positive of that. I also have the thin stamped metal plate installed as well
                  • dreamer420
                    • Sep 2009
                    • 468
                    im pretty sure you dont lube the teeth, as they are exposed. and no, the noise wont just go away on its own. it will get worse until it works no more.
                    I think its the position of the starter itself that causes this.
                    on mine when i removed it the flywheels teeth had been chewed up on parts of it, so its not good to leave it.
                    • 5Toes
                      • 9836
                      Yeah lubing the teeth wont help much, but that was just an idea
                      Could I be missed anything?? Maybe not torqueing it down tight enough? I have had this starter, and the other, on and off about 5 times in the past 2 days. I can do it now in about 10 minutes :)
                      I have the flywheel order correct, and I also have the stamped steel plate between the block and the tranny, so I believe I have everything I need
                      • 5Toes
                        • 9836
                        Any ideas at all??
                        • McGyver
                          • 4636
                          Originally posted by 5Toes
                          ...Any ideas??? I am stumped and need my car
                          oh the irony of that statement
                          (sorry)
                          • 5Toes
                            • 9836
                            I believe I am missing the wave washers... might be the cause of the problem.
                            I am going to Lowes tomorrow to get some thick washers and see what that does
                            • 5Toes
                              • 9836
                              This noise
