I have an 87 325ic. I cannot find any information on when the e30's first started having check engine lights... If mine has it, the bulb might be burnt out... Any thoughts???
Check engine light question
84 Henna 325e - 88 Delphin 325iC -90 Schwartz 325is - 93 AW740iL - 01 Titan 740iLSportTags: None -
Correct, and since they were kind of an afterthought, they are frequently missed on reinstallation of the instrument cluster since they have to be installed in a port separately.
If you wanted it for diagnostic reasons, the 153 DME in your '87 sports something like four not very helpful codes. Your better off diagnosing driveability issues the old fashioned way.-Dave
2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
Need some help figuring out the ETM?Comment
Cool thanks guys. Would this by chance be the light that has two plugs that comes off of it???84 Henna 325e - 88 Delphin 325iC -90 Schwartz 325is - 93 AW740iL - 01 Titan 740iLSportComment
Yep thats probably it.-Dave
The abs light also has two prongs and plugs into the cluster. make sure you have the right one. Looking at the back of your cluster, the abs light hole will be on the left side, and the check engine light hole on the right side.
^ good catch.-Dave
Cool, thanks guys!!84 Henna 325e - 88 Delphin 325iC -90 Schwartz 325is - 93 AW740iL - 01 Titan 740iLSportComment
