No start help
  • bpmack16
    • 1521
    No start help
    So today I went at it again,
    New plugs
    new fuel filter
    I have spark to the cap
    have spark to the plugs
    I can hear the fuel pump go on
    Noid light hooked up under the throttle body to fuel injector plug. (light goes on when car is cranked)
    NOW, COULD I HAVE A CLOG IN THE FUEL LINES, BAD GAS, BAD INJECTORS, SHOULD I HAVE PLUGGED THE NOID LIGHT IN TO THE FUEL RALE WHERE AN INJECTOR WOULD HAVE GONE?
    All the fuses are good and I replaced the crank sensor. HELP ME....
    CONTINUE TO THIS
    The proper use of the noid light is to connect it where the injector connector attaches to an injector. Check both banks for firing pulses.
    • bpmack16
      • 1521
      Originally posted by jlevie
      the proper use of the noid light is to connect it where the injector connector attaches to an injector. Check both banks for firing pulses.
      check both banks for firing??? What do you mean by banks???
      • M-technik-3
        • 18946
        The issue is under your intake the connector for the fuel injectors gets corroded.
          The injectors are organized and operated as two banks of three. Bank one is cylinders 1, 3, 5 and bank two is cylinders 2, 4, 6.
          • bpmack16
            • 1521
            No that is fine I checked it and it has power and looks good.
            • bpmack16
              • 1521
              Thank you i will check that now.
              • bpmack16
                • 1521
                So i got the noid in to the first injector and the last injector and they all light up so the injectors are getting pulse. The fuel pump works and the filter is new. The spark plugs are new and have spark at the cap and spark plugs. Do you think the timing may be off? I never messed with the rotor or timing belt but can these things jump and notch? Any help would be help.
                  You have spark and injector firing. What is the rail fuel pressure when cranking?
