hesitation??
  • 09june29
    • Apr 2012
    • 38
    hesitation??
    hello i am in need of help with my 87 325e its the 2.7 and it started acting up a few days ago and keeps doing it... ok when i start my car in the morning it runs fine and seems pretty quick all of it power and once the temp gauge moves a little or gets a lil warmer it starts to hesitate when im 75%-!00% throttle doesnt hurt my mpg or driveing ability just get mad cuz it does this also its a noticable power loss no get up like its suppose to it sometimes idles funny and bounces from 600-900 when its warm also .. anyone have any suggestions ?
    The first thing that comes to mind are intake leaks. They can only really be found by having a smoke test run.
    • 09june29
      • Apr 2012
      • 38
      how can i do this? sorry nvr done it befor... well it started doing this after a dry rotted fuel line was leaking and i fixed that but has done it since
      • 09june29
        • Apr 2012
        • 38
        smoke test?
        • hamilton325i
          • Sep 2011
          • 83
          You need to track down a shop with a smoke machine capable of diagnosing vacuum leaks (even tiny) on your particular vehicle. BMW dealers, in theory, should be your best bet.
          • dnguyen1963
            • Nov 2011
            • 2651
            search www.scottykilmer.com for a cheap cigar smoke test if you cannot locate a decent shop.
            • 09june29
              • Apr 2012
              • 38
              i dont have a bmw dealer nearby
              • MrNatural
                • Apr 2008
                • 237
                check your cap and rotor...
                • 09june29
                  • Apr 2012
                  • 38
                  Good idea anyone have good idea how to clean a cap n maybe the rotor
                  • hamilton325i
                    • Sep 2011
                    • 83
                    The BEST way is to replace them with new components. You can lightly sand the posts on the cap and edge of the rotor to remove corrosion but isn't a guaranteed fix.
                    • 09june29
                      • Apr 2012
                      • 38
                      Thanks guys I'll just replace them and fuel filter and I'm thinking the coolant temp sensor could be the problem could anyone post a pic of what coolant sensor I'd need to change lol
                      • hamilton325i
                        • Sep 2011
                        • 83
                        I wouldn't just start throwing parts at it. Try pulling apart the cap and rotor as mentioned and checking for corrosion. if sanding them down a bit makes a difference then you may be on to something. Otherwise you may just be wasting money and no closer to your goal. Just my 2 cents.
                        • 09june29
                          • Apr 2012
                          • 38
                          Yea thnx man I guess it's worth a shot
