M20 Oversize valves
  • E30-325iS
    • Sep 2011
    • 191
    Thanks Digger, it is definitely worth explaining as I don't have as much knowledge as I would like, and any input no matter how trivial or basic it may seem is most welcome, hence the thread.
    • tinkwithanr
      • Jun 2010
      • 377
      Glad to hear the IE valves are improved, never hurts to have another quality option for BMW parts.
      Also, later today I'll get a picture of my VAC valves. They are slightly different than those in Digger's pictures (coated, maybe a slightly different shape to the head). It would have been nice to have this kind of info in one place when I was shopping around for parts before.
      Tinker Engineering - 2014
      Mica - 2000 BMW 323i - The one that started it all
      Fiona - 1975 BMW 2002 - The Definition of Project Creep
      Heidi - 1988 BMW M5 - The piece of BMW history
      Silvia - 2013 Subaru WRX - Stock, for now
      • E30-325iS
        • Sep 2011
        • 191
        Thanks Tinkwithanr, looking forward to the pics.
        • einstein57
          • Jun 2007
          • 10780
          Anyone have info on the valves TEP sells?
          www.gecoils.com
          • tinkwithanr
            • Jun 2010
            • 377
            Here are some pics of VAC's valves. I can't speak personally about any of the other options, but I am very happy with my purchase. The machine work and finish was top notch, my machine shop (whom specialize in billet aluminum CNC'd big blocks) even commented on how nice they were.
            + 1mm Intake Valve (43mm)
            +1mm exhaust valve. Here you can see the difference in the head shape on the intake and exhaust valve (intake in the rear of the pic). Like Digger mentioned before, these have a flatter crown on the intake valve to help aid flow. The exhaust valve has a more tradition bell shape to it.
            And here are some pics of them installed:
            • SpecM
              • Oct 2005
              • 4531
              do the seats have to be opened up any special way to use +1 valves?
              1989 cirrisblau-metallic 325i
              • digger
                • Nov 2005
                • 6171
                out of curioisty when did you buy those valves from VAC and was the a brand name on the stem?
                • whodwho
                  • Jun 2008
                  • 1547
                  They look like the Black Nitrided Supertechs
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • digger
                    • Nov 2005
                    • 6171
                    which are the same as the one i got from PPF (i.e have the backcut already done), but i am wondering if VAC now use the Manley ones instead becasue that is what i got late last year
                    • tinkwithanr
                      • Jun 2010
                      • 377
                      I got them roughly a year ago. I don't recall seeing a name on the stem when I looked them over, and they are currently installed so I can't check.
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        VAC ftw
                        m20 is plenty. im simply a drifter.
                        build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                        • e30conv2
                          • Sep 2009
                          • 168
                          Vac Motosports or Metric Mechanic is the way to go. Ireland Engineering has mostly Asian parts. Our E30's are German. Most Asian parts are compromised in manufacturing German aftermarket parts believe me I have been working on German cars for twenty five years plus. You get what you pay for 99 percent of the time.
                          • tinkwithanr
                            • Jun 2010
                            • 377
                            Correct me if I'm wrong, but I don't think IE imports their parts. While there may be differences between the vendors, the cost of the parts along with the target consumer is also different.
                            If I'm just rebuilding a stock head to go on a stock bottom end, it makes sense to spend half the price for a valve that will match the performance of the other components in the build. Likewise, considering the amount of money I currently have in my stroker build, the $250 difference in price was minimal and gave me valves that would be a better match for the rest of my build.
                            • digger
                              • Nov 2005
                              • 6171
                              i'd only be looking for oversized valves if overboring the block on a stroker so that the amount of shrouding between the valve and cylinder essentially doesnt change.
                              MM dont even use OS valves so what does that say for the size of stock valves? or their heads? Either stock are way too big as it is or MM are too small.
                              without some decent head work i dont think the OS valves would do much, the seat needs to be modified accordingly and you want a multi angle valve job.........where does it end?
                              • SkiFree
                                • Jun 2011
                                • 2766
                                Originally posted by e30conv2
                                V Ireland Engineering has mostly Asian parts. Our E30's are German. Most Asian parts are compromised in manufacturing German aftermarket parts believe me I have been working on German cars for twenty five years plus. You get what you pay for 99 percent of the time.
                                Originally posted by SkiFree
                                IE: $276 for full set [NOT made in China, Tawain, etc]).
                                ADAMS Autosport
