eta head with I cam?
  • ajemayer
    • Apr 2012
    • 4
    i have a '86 325e and am looking for ways to improve hp while saving for a m52 swap. I plan on doing the motronic 1.3 upgrade from my 1.0. Is it worth my time to swap a "I" cam and springs into my "e" head? How much gain will I see from just the ECU upgrade? I appreciate any input.
  • TobyB
    • 5286
    Well, there's a firing order problem- the eta and the i fire in different orders...
    Can you jsut swap plug wires around? I would think so...
    If you resolve that, then you need to drill the bosses on the eta head to oil the i cam.
    Beyond that, I know nothing!
    heh.
      The intake, valves, and ports on the ETA head are smaller than those on an I head, so just changing the cam, springs, engine harness, DME, etc., aren't worth the effort. Making a "budget stroker" would be worth the effort, in which case you'd change the head, intake, injectors, AFM, harness, DME, and add the M20B25 CPS.
      • ajemayer
        • Apr 2012
        • 4
        I've done my research and have the parts list, just wondering if its worth all the work if i keep my 200 head. I know with the "I" 885 head my C/R will drop. I know a 731 head would be ideal but I cant seem to find one. Has anyone just done the 1.3 upgrade with the stock eta? Is it worth all the work?
        • Cabriolet
          • 9620
          instead of doing all this work for just some power, why not go S50b30? its well documented and there is parts for everything needed to do it.
          Much wow
          I hate 4 doors
          • ajemayer
            • Apr 2012
            • 4
            I have plans to do a swap in the future for sure, probably by this time next year. Don't have the funds for it yet hence the question about the ECU upgrade.
              • 37833
              Honestly, it's not worth even messing with the Eta engine if you're planning to swap.
              Throw in a 3.25 LSD and a chip and enjoy!
              Grover Beach, California
              BimmerHeads.com
              • MrNatural
                • Apr 2008
                • 237
                This ^^^^ it will be more fun while you wait
                • SpecM
                  • Oct 2005
                  • 4531
                  Agreed ^ if you plan on swapping soon anyway
                  Toby: etas and i's have the same firing order. All BMW sixes do
                  Sent from my Vortex
                  1989 cirrisblau-metallic 325i
                  • ajemayer
                    • Apr 2012
                    • 4
                    I actually have a 3.25 LSD and chip already. Did those about a month ago. This is primarily a track car. The chip and LSD made a huge improvement. I was just looking for a little more power for the track untili can get to the swap in about a year or so. I've also upgraded the suspension to the J stock kit from Turner. The car is a blast to drive, just looking for a little more power. I have the time and am willing to do the work as long as its worth it. Shouldn't take more than 2 weekends to swap everything over from what it sounds like.
                      • 37833
                      Instead of spending the $500-ish on a few extra HP now you should save the cash and change your swap plan from M52 to S52. ;)
                      BimmerHeads.com
                      • cunninglinguist
                        • Mar 2004
                        • 281
                        heh.
                        • Cabriolet
                          • 9620
                          heh.
                          wtf? no. all m20s fire in the same order 1 - 5 - 3 - 6 - 2 - 4
                          Find information, resources and relevant links for e30world.com. This domain may be for sale.
                          Much wow
                          I hate 4 doors
                          • sce30
                            • Mar 2012
                            • 10
                            um check this out.
                              • 37833
                              Originally posted by sce30
                              $200 to drill a few oil passages in your cylinder head.
                              Not only do you have to send your head to VAC, you have to tear it down too.
                              Not worth the trouble.
                              BimmerHeads.com
