86 325e 325i engine harness question!
  • dirty thirty
    • 372
    Doing my swap now and im having a little problem routing my engine harness.
    the harness has been sitting in a box for over a year and its not going anywhere i route it.
    first problem
    The two group wires right next tot he grommet for the ecu on the firewall.
    The two group of red wires i have connect to the batter + on the firewall
    are these sapposed to go here?
    larger pic
    Next the big black cable coming from battery+ where does this go, the starter?
    thanks you for your help!
    Just out trying to build some boost !!
    Stroked and blown 328i @ 15psi
  • e30trooper
    • 11576
    the two ground wires ground out on the battery tray.
    what year is your car and what year is that harness from?
    • Cronopoulos
      • Jul 2011
      • 2187
      I would say you are correct here.
      Project log -- DIRTY 30
      2.7i * Megasquirt tuned * E85 powered
      • dirty thirty
        • 372
        the car is an 86 and the harness is a 91 380 ecu
        • dirty thirty
          • 372
          Were on the starter? The back?
          • dirty thirty
            • 372
            The big wire for the starter goes where on it ?
            • BavBeater85
              • Mar 2012
              • 143
              starter should have different sized studs, so youll be able to match by eye if you have the right ones running to it
              may you rest in peace, or pieces, whichever comes first
              • BavBeater85
                • Mar 2012
                • 143
                that sucks, my i motor came with the wiring harness till hooked up, even the starter was still on the engine and wired
                • dirty thirty
                  • 372
                  Does any one have a pic of the starter installed in vehicle ?
                  • dirty thirty
                    • 372
                    Now i have the big black wire from battery pos on the wire wall and the red positive cable coming from the loom hooked up to the starter soleniod. there is a blck ground wirte that runs in the loom next tot the small red starter wire. where does this black ground cable connect to on the starter?
                    • Bretts85E30
                      • 340
                      Far as i know the only wires that goto the starter power and ground wise connect directly to the solenoid and the ground mounts directly to the frame or block whichevers easier
                      • e30trooper
                        • 11576
                        • dirty thirty
                          • 372
                          Thank you i got it now !
                          • dirty thirty
                            • 372
                            Do bolth of these go on the two post on the starter soleniod.
                            • Bretts85E30
                              • 340
                              That would be my best guess there are 2 posts on my early eta starter but i only have the shrouded wire on the left that connects to the solenoid on the top
