Injectors for my stroker.
  • jules325i
    • Jul 2011
    • 353
    I just got my stroker running and need some bigger injectors because i am running stock ones.
    where do i buy them.
    What size do i need (2.9 stroker)
    also I'm running a alpina copy chip will this be ok.
    329i
  • sayed ali
    • 762
    30# are fine.. even 24# too
    but make sure if that chip will be supporting those injectors, otherwise get a new one with the new injectors combo
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • digger
      • Nov 2005
      • 6075
      might be able to get away with 19lb depedning on what specs you have build the engine to, quite often strokers dont make a whole lot more peak hp
      • jules325i
        • Jul 2011
        • 353
        Well its a 2.9l, 10.5:1 cr, schrick 272 cam, with extensive head work.
        329i
        • digger
          • Nov 2005
          • 6075
          19lb would probably do it, 21lb at the most for some margin
          • CptnVortex
            • 46
            I got my 19lb Mustang Injectors from Maksim : http://www.r3vlimited.com/board/showthread.php?t=242072.
            Working great on my Miller PSIK Tuned 2.7L.
            • BMW_325i
              • 61
              So these 19Lb Mustang injectors 0280155710 are a direct replacement physically for the OEm injectors?
              1988 Lachssilber E30 325i sedan.
              Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
              Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
              Retired - '83 Arctic Blue E28 528i powered by M30B32
              • CptnVortex
                • 46
                Yes, they are a different design, and plastic vs metal, but they fit like stock. No modifications required.
