timing belt loose upon teardown
  • jbruch694
    • May 2012
    • 44
    Hey all, I'm new here. I did some searching and couldn't find any info on the issue I'm having. I just picked up a 1987 325is about a month ago, it needs a lot of work and I'm just starting up on that. I need to overhaul the whole cooling system and replace a bunch of leaky seals, and I ordered a kit from pelicanparts.
    I started tearing it down last night, and got to pulling the timing belt covers and balancer. The timing belt was very very loose even with the tensioner spring and everything still in, and I went to line up the cam and crank markings, and when the crank mark is lined up, the cam is about 2 notches to the right of where it should be. I'm not sure if the belt is stretched or the tensioner isn't tightened all the way or what, but either way its pretty screwy. It wasn't running too great before, and I guess this is why.
    My question is, would I be safe setting the crank to where it should be, taking the belt off and rotating the cam to its mark? I'm thinking this would be fine, I just wanted to double-check.
    Thanks, JB
    • 34844
    yes that will be fine
    be sure to replace the tensioner, and consider a new spring (perhaps it's damaged).
    • jbruch694
      • May 2012
      • 44
      alright thanks. yeah I have all the new stuff, tensioner, spring, pin, everything in that general area to replace, I just wasn't sure what to do about that specific situation. Thanks.
      • PNWDan
        • Feb 2011
        • 1326
        Its about $60 for a belt and tensioner. Just do it all while your there
        1987 Alpinweiß 325is
        Like the PNW E30 Local Crew Facebook page
        • $hane
          • May 2011
          • 366
          When i first did mine i pulled it off without loosening the tensioner. It was rubbing on the cover because it was trying to come off. Replaced it and tensioned it properly and all was well.
