'87 325e - 327i Dyno results
    Wow soo good, i can't wait to do a head swap.
    [/quote]
      nice! actually, that's one of the better HP/torque curves i've seen from a 2.7/head swap. perhaps the 323i head is a better match than the 885 to the flat-topped pistons - those always end up being a bit down on power compared to a stock M20B25, just more torque. yours is about dead even on power and definitely more torque.
      Originally posted by durtyE30 View Post
      ~178HP @ Crank
      Very respectable.
      I'm donig an 885 head onto an 86 325e bottom end. Thinking of building the head up some, to get ~ 200HP @ crank ideally.
      what the hell sort of drivetrain loss are you using? there's no way it's 178bhp.
        Originally posted by Gary Horneck View Post
        After planning this conversion for a year, I just had to see what the final results were. Wish a baseline 325e pull had happened, but from what I can find, looks like about 75-80 rwp? Is there a common formula for our cars to roughly determine crank output from rwp? I guessed seat of pants, a 60hp increase over the eta.
        stock eta should be more like 105-110bhp, not 80..
        here's one that put down 112whp at 3900rpm:
        it's definitely a big improvement over a stock eta, but it's certainly not a 60hp increase.
          Just going by the few assorted youtube videos showing a 325e on a dyno. Still think it was worth the conversion. Amazing that a 121hp engine only lost 9hp in frictional losses though.
          2011 335i/1995 Mercedes C220 (rallyx)
            it was probably underrated like many BMW engines
            anyway, even if you use a pretty standard HP loss (~15%) it still ends up at ~105whp.
              Yup, my stock 1983 528e freshly tuned produced the following on the York Automotive dyno in Mt. Airy, MD:
              - 106.5 RWHP with stock ECU
              - 122.3 RWHP with E.A.T chip
              I talk about involving various ECU chips here and my experience with chips on other M20 engines in poor states of tune.
              -Rod
              Rod's 528e support web site
              A car can be restored many times. It is original only once.
                LOL that was my old eta
                Had 88 rwhp @ 4950 rpms , no chip just cone filter and cheap axle back muffler. Had tons a intake leaks. This was 3rd gear pulls
                This dyno read low #s so maybe on others might be around 95ish whp
                  ok ill be that guy.... how does this effect the awesome efficiency of the eta.... you guys probaby are having to much fun to care but im interested in a stroker for my ix esp if i can get better mpg and keep similar power/more torque.
                    With the 2.93 i still get great MPG. Even with the 2.93 the car still flys, however there's plenty of room for improvement
                    1st and 2nd gear pull , eta block with refreshed/decked 885 head full 1.3 swap , ebay b3 chip copy. open 2.93 diff
                      [quote=e30trooper;3232318]With the 2.93 i still get great MPG. Even with the 2.93 the car still flys, however there's plenty of room for improvement
                      cool thanks man. any approx numbers for gas mileage?
                        [QUOTE=iXe<30;3232499]
                        no idea, my odo. doesn't work
                          bummer.... i think im gona go ahead with this instead of pulling my i motor for a refresh. thanks for the thread guys. Anyone close to pa have an eta block fs?...
                          Edit: woah sorry for the thread jack ill stop now..
                            This is great to hear! I have been staring at a complete lot of parts for a 731 head based swap. Im feelin motivated to jump on it.
                            OP...did you ever consider 19# injectors or an MAF?
                              Two AutoX's later, and making quite an impression on the Street Prepared class. I now run in DSP, and have taken class twice, and a FTD in SP Sunday. Second run of the day on Sunday...
                                A small update on my car. Installed a 3.73 lsd last week and tracked the car on Sunday.
                                WOW , after all that work and then installing a proper gear ratio the car pulls great. With all season tires I can chirp 3rd gear all day long. On the track I couldn't get grip due to the tires. However on a uphill pull ( top of 2nd and mid 3rd gear ) i pulled about a car and half on a s2k. So mid range power is where its at. Im lovin it!
