Fuel Pressure after engine is off???
  • RGCintha29073
    • Dec 2009
    • 471
    So, i replaced my bad fuel pump with a TREPerformance pump.
    Now the vehicle is starting to get hard to start. After attaching a fuel pressure gauge and observing the pressure. Right after I turn off the vehicle the fuel pressure drops straight to 0! Normal? Is there a return valve in the line that is stuck open? Shouldn't there be some pressure after?
    It sounds like your TRE pump doesn't have a check valve in it. The OE pump does. If the OE pump and FPR are good, the rail will remain pressurized for a really long time.
    • RGCintha29073
      • Dec 2009
      • 471
      Thanks. Thats what i thought but wasnt sure. Ill be looking for another pump here soon.
      • E30-325iS
        • Sep 2011
        • 191
        You can buy a check valve for a few dollars. Part number is in this thread.
          Just get an OE pump and be done with it.
          • E30-325iS
            • Sep 2011
            • 191
            You're right,of course, that would be the best solution.
            I remembered seeing that thread, and was trying to provide a cheap alternative.
            • RGCintha29073
              • Dec 2009
              • 471
              Thanks. Seems the valve is MIA so looks like it will be a pump. I may try to look it up on my ETK program and see if the part number has changed.
              • sayed ali
                • 762
                I used the 2jz-gte pump replacing the stock one in tank, it's stronger, better response, no hard starts, no pressure drops, cheap ..
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
