i've had an issue for the past year or so that has really begin to bother me. when letting off throttle after any load (even in traffic situations), my rpms will drop to 350-400 before catching back to ~600 idle. any theories? my idle is also lumpy (like a cam) and goes through 5 second intervals of falling lean then coming back.
off-throttle rpm drop
TPS was tested and okay. blasted the hell out of the ICV and temporarily fixed the drop-down but it came back. adjusted the idle up a little and the drop isn't nearly as severe. still would like to figure out the lean cycle though.
swapped out the fuel pump for kicks too.
did a pull last night and 4th gear ran flat at 5800 RPM on flat ground. never had that issue before. the top end seems to not pull as well as it used to. compression numbers are 155-165 across all 6.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
