e to i swap, harness questions
  • mbonanni
    • Sep 2011
    • 6236
    I have a 1987 325e, I acquired a 1987 325i wiring harness.
    I have started to put the harness is an just noticed that there seems to be extra connections in the glove box. I have two single wire connectors. One has a white male plug and the other has a black male plug.
    I also have a green box inside my glove box, but this new harness does not have a plgu for it. Does this mean that I get rid of the green box?
    can anyone help me?
    *I reused an old thread*
  • Robotin
    • Jun 2011
    • 4471
    yes, late model I cooling is different. i will to grab everything that is differnt! the radiator. just go look at an I.
    see what is different. and grab it.
    thats what ive always done.
    1989 325i SETA stroker [delphin] R3V'd 8/31/2011
    1989 325ix [zinnoberrot] $OLD
    1970 2002 [Nevada]
    Originally posted by Herr Faust Schinken
    guy must have slid into something that doesn't look like a car vs car hit
    Originally posted by ak-
    Must of slid into Rob
    • mbonanni
      • Sep 2011
      • 6236
      So I want all the cooling as well.
      I will add what you guys say in a diff color. lol
      • Cabriolet
        • 9620
        intake mani and exhaust(whole system is different)
        O2 sensor
        Much wow
        I hate 4 doors
        • Albuquerque30
          • 1349
          If you want, you can take a look at my car and check out the differences.
          WTB NorCal: Z4 shifter + misc. parts
          • mbonanni
            • Sep 2011
            • 6236
            That may be what I need to do, but the guy I am emailing seems to know his crap.
            If I give him a list he will tell me if he has it or not.
            If anyone else can add to that list I would appreciate it. I want to pick up a motor within the next week or two
            • mkcman17
              • Jul 2010
              • 8240
              late model cooling isn't a necessity. the key parts are the vacuum lines and electricals.
              1989 LN106 Hilux / 3.0TD SFA
              1974 2002tii / stock
              2002 IS300 / 5spd LSD
              • Albuquerque30
                • 1349
                Just send me a PM, if you need to. Plus, it's an excuse to meet another e30 guy.
                  • 37827
                  You can just use the car's original cooling system if you want.
                  If you get a wiring harness from an 87 i/is/ic everything will be plug and play.
                  Classic BMW Specialists
                  Santa Clarita, CA
                  www.BimmerHeads.com
                  • mbonanni
                    • Sep 2011
                    • 6236
                    Thanks guys!
                    I will most likely get the harness from this guys and just continue to look for an 87 one.
                    So overall does the list look good?
                    • mbonanni
                      • Sep 2011
                      • 6236
                      Do I need to get the flywheel from an i?
                      • efficient
                        • Feb 2012
                        • 3312
                        Im in the same boat as op, I was reading that you use the late model waterpump, so you dont have to replace all the coolant parts to the newer coolant system. is that true?
                        • StereoInstaller1
                          GAS
                          • 22679
                          You certainly should, the ETA flywheel is typically a dual mass turd
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • mbonanni
                            • Sep 2011
                            • 6236
                            Thanks!
                            I will add that to the list later when I am not on my phone.
                            • mbonanni
                              • Sep 2011
                              • 6236
                              Edited first post guys ;)
