e to i swap, harness questions
  • mbonanni
    • Sep 2011
    • 6236
    Ahh cmon guys, I know you have some ideas.
    • paperplane94
      • Jul 2011
      • 420
      Also buy a camshaft seal and cam seal o-ring. BUT you must be very careful when removing the cam sprocket. (search:my username, "cracked cam")
      You should adjust the valves and if the head hasn't been serviced you will need a valve cover gasket and new rocker shaft rubber plugs.
      The waterpump has a gasket too, FYI.
      I got a new timing belt tensioner pin and spring as well.
      Grab a tube of RTV, you might need it for stuff.
      This is all stupid stuff though, it seems you've got the major items down already.
      • mbonanni
        • Sep 2011
        • 6236
        every bit helps.
        Thanks
        • Cronopoulos
          • Jul 2011
          • 2187
          Good luck, along with many others that have done this, i also offer any help you may need. Let me know!
          - Kyle
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • mbonanni
            • Sep 2011
            • 6236
            Are there any head gasket/top end gasket kits besides Victor Reinz?
            I want to get all the gaskets for the top end in one place/kit if I can.
            • mbonanni
              • Sep 2011
              • 6236
              Alright guys I updated my first post with things I have found I should replace.
              I am most likely ordering tomorrow, so if you could add (or have me remove) anything before 2 am then that'd be great ;)
              Thanks
              • dougie30
                • Apr 2012
                • 1708
                i really want do do this swap, so far it sems pretty easy. is there a build thread for a eta to i swap?
                M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                • mbonanni
                  • Sep 2011
                  • 6236
                  I was unable to find one, but if you want I can tell you everything you need (or at least what I was told by others).
                  Pm me
                  • MattAvino
                    • Jan 2011
                    • 2147
                    Just so you know I have a perfectly running 87is m20b25 for sale (harness too)
                    Let me know if you need anything from it.
                    I also have a g260 for sale also.
                    E30 buildy things
                    http://www.r3vlimited.com/board/showthread.php?t=195286
                    • $hane
                      • May 2011
                      • 366
                      i got the VR set and just tossed the head gasket.
                      • mbonanni
                        • Sep 2011
                        • 6236
                        Bump,
                        I edited my first post to ask a different question.
                        • TG Goose
                          • Jul 2011
                          • 234
                          You certainly should, the ETA flywheel is typically a dual mass turd
                          My ETA (1986) had a 23lb single flywheel. Machined it down to 15lbs.
                          ______________________________________
                          1984 LSB 318i - Sold
                          1986 325i - Motor Swapped Track Car Project
                          1995 318ti - Sold
                          1999 540iA - Daily Driver
                          • mbonanni
                            • Sep 2011
                            • 6236
                            getting a single mass and just resurfacing it.
                            Thanks
                            • KEVORM
                              • Jul 2011
                              • 237
                              Bump,
                              Your c104 plug has 3 wires
                              Pin #1 Black Wire-Engine speed
                              Pin #2 green wire-OBC Fuel cut function
                              Pin #3 Yellow/White wire-Fuel rate
                              On the 89 harness you'll need to splice or connect the following wires to the ones on the c104.
                              Pin # 3 from c104 to Pin 8 on the c101 of your 89(Yellow/White or White/Black wire)
                              Pin #2 from the c104, run a wire from directly to the + terminal on the coil(Green wire)
                              Pin #1 from the c104 to pin 9 on the c101(black wire)
                              From: http://www.e30tech.com/forum/showthr...t=28921&page=2
                              84' 325i -> PRO3 #304
                              Powered by Manntechnik
                              Work in Progress Build Thread
                              • mbonanni
                                • Sep 2011
                                • 6236
                                Thanks!
                                Is the c104 the harness or my car?
                                Link doesn't work btw.
