M54 Crank for Stroker?
  • GoFaSSter
    • Mar 2012
    • 7
    I am looking at a crank from a 328i E46 M54 engine, or so the seller says. I want to use this for a stroker in my M20b25. My question is that according to one thread that I read from the UK, you should only use pre 1998 crank because of the Dual vanos upgrade to the engines. It also states that a dual Vanos or TU crank can be used but requires more modifications to block and pistons.
    Can anyone enlighten me and tell me if I can use this crank just as well as an older one? Or what modifications must be done to make this crank work if I move ahead? Lastly, if anyone one in Norcal has a non vanos crank from and M52 they want to sell that will drop in that would be great.
    Sorry for the questions, but I did not find my answers on the search, but maybe I did not dig deep enough. Thanks in advance:D
  • sayed ali
    • 762
    My buddy has one in his turbo m20, with stock everything in the motor beside the O-ringed block..
    It's add a really big torque, but he always used to have problems with it like something breaking or so, I don't know exactly but it's really a great upgrade
    I have one but I'm thinking of putting pistons, rods from e36 328i and that crank
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • SpecM
      • Oct 2005
      • 4531
      An e46 328i will have an m52b28tu, not an m54
      Sent from my Vortex
      1989 cirrisblau-metallic 325i
      • tinkwithanr
        • Jun 2010
        • 377
        What Spec said, the e46 328's have an m52b28tu which does have the largest counterweights of any stroker cranks that I have seen. So bascially you would need to either cut down the counter weights a lot as well as the skirts of the pistons, assuming you aren't getting custom forged ones.
        Are you going to a 2.8L?
        Tinker Engineering - 2014
        Mica - 2000 BMW 323i - The one that started it all
        Fiona - 1975 BMW 2002 - The Definition of Project Creep
        Heidi - 1988 BMW M5 - The piece of BMW history
        Silvia - 2013 Subaru WRX - Stock, for now
        • GoFaSSter
          • Mar 2012
          • 7
          Thanks for the help guys. It is an EBay thing and I am not aware enough to know exactly which crank I really should have. I am doing something similiar to your 2002 build tink'. I am working towards a stroker M20 for my '75 2002. I have an M20b25 and an M20b27. I was looking to use the m20b25 "i" pistons. The block measures good and still has all the crosshatching. I was going to hone and re-ring. The 130mm rods after they are reconditioned and an 84mm crank. Any suggestions or comments. I would like to be in the 9.5-10.0:1 compression range.
          • tinkwithanr
            • Jun 2010
            • 377
            To get that compression your probably going to need either custom pistons or the high compression euro pistons which were ~9.75:1 (I forget what they came in though). If you haven't checked out the stoker threads on the 'other e30 site' I'd recommend you do that, they have a wealth of information in them. That's where I started and by the end I was able to answer most of my own questions.
            • downforce22
              • Aug 2009
              • 3192
              I've got a set of those pistons with a bit of damage, but overall good shape ;)
              • GoFaSSter
                • Mar 2012
                • 7
                PM sent.
