idle problem
  • 93zk
    • Sep 2011
    • 60
    idle problem
    so on my 87' 325e I'm experiencing a high idle at around 2500 rpm. then after about 10 seconds it drops down to 1000 and goes back up to 2000 every other 3 seconds. could this just be my idle control valve? ill squeeze the hose and it will run like normal. engine runs very hot after only maybe 5 min of running like this. thermostat problems? checking the voltage to my battery runs at 12 volts. not 13 or 14. could the idle problem be caused from the alternator? also im running a straight air intake. no box. and the rubber elbow is a little caved in. any suggestions?
  • e30Villain
    • Jun 2012
    • 540
    Sounds like the Coolant sensor in thermostat housing and your icv. By hot, how hot do you mean. E30s go to the 3/4 line when they are not moving. As long as its not above the third line, your good, although 5 minutes is a bit too early to be going that high.
    87 ETA | Hibernating
      If the cooling system, and especially the fan clutch, is working properly the needle should not go more than a hair above the half way point at any time.
      As to the OP's idle problem, a dirty ICV and/or intake leaks are the most likely causes. Remove and clean the ICV and have a shop run a smoke test on the intake/block and fix the leaks the test reveals.
      • dnguyen1963
        • Nov 2011
        • 2651
        You have got a big problem with your fan clutch or your radiator is about to take a crap. Temp should never go to 3/4. The only other time that the temp gauge goes to 3/4 with normal engine temp is when your SI board/batteries has gone bad.
        • e30Villain
          • Jun 2012
          • 540
          You guys are right. My mistake. My car does not reach the 3/4 mark I was speaking on behalf of other member's but looks like I mixed it up with the half mark.
          • dougie30
            • Apr 2012
            • 1708
            my 325e does this too! but some times it stayes reving at 2000, so fucking annoying so you think its a dirty icv, or a intake leak would make it rev up like this?
            M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
            • Gregs///M
              • Mar 2012
              • 2459
              Yup, clean the ICV and check for vacuum leaks.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
              • 93zk
                • Sep 2011
                • 60
                haha so i must be retarded. it was my fuse that blew for the idle control.
                question, how can i check for an intake leak with carborator cleaner. do i just spray it on and see if the engine revs higher? where exactly do i spray it? or is there another way to check for leaks without taking it to the shop
                • UserError
                  • 86
                  Carb cleaner can find some intake leaks, though it's nowhere near as effective as a smoke test. You should spray while the engine's idling, and hit every vacuum hose, fitting, gasket, and on the intake boot, though a visual inspection of the boot usually reveals leaks coming from there.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    www.scottykilmer.com and search for cigar smoke test.
                    • 93zk
                      • Sep 2011
                      • 60
                      thanks that helped a ton!
