had my m20 dynoed
  • iwantspeed
    • 3164
    had my m20 dynoed
    So a member posted in here about a discounted rate for a dyno day
    http://www.r3vlimited.com/board/showthread.php?t=250795
    https://www.facebook.com/events/310165325736320/
    big thanks to Jlieve
    been trying little by little to get all the maintenance done on this engine setup.
    engine specs
    Intake
    • · Stock air box
    • · Upper snorkel removed
    • · K&N drop in air filter
    • · New intake boot
    • · New throttle body gasket
    • · Removed throttle body heater
    • · Intake manifold wrinkle finish black
    Head
    • · Hot tanked and pressure washed
    • · Head decked 0.06
    • · Shot peened rockers
    • · New inner and outer valve springs & keepers
    • · New intake and exhaust valve guides
    • · New intake and exhaust stem seals
    • · All Valves lapped
    • · Fresh Valve seats
    • · Intake and exhaust ports have been enlarged to match the gasket
    • · Wrinkle finish valve cover
    • · .011 thousands snug COLD valve adjustment
    Ignition
    • · Ireland Engineering
    • 8mm spark plug wires
    • · NGK zgr5a - 5077
    • · New Bosch Coil relocated to battery tray
    • · New Bosch cap
    • · New Bosch rotor
    Fuel
    • · New Fuel pump
    • · New fuel filter
    • · New rubber fuel hoses in the engine bay
    • · Rebuilt and flow matched injectors by R/C engineering
    Fluids
    • · Castrol 20w50 oil
    • · Prestone coolant/ Distilled water
    • · Ate super blue brake fluid
    Exhaust
    • · Stock manifolds
    • · New o2 sensor
    • · Secondary o2 sensor bung welded in x pipe for a wideband gauge
    • · Stromung cat back exhaust
    Cooling
    • · Mishimoto e36 m3 radiator
    • · All new coolant hoses
    • · Heater thermostat valve removed
    • · Heater core valve replaced
    • · Throttle body heater removed
    • · Graf water pump metal impeller
    • · New expansion tank
    Electronics
    • · Motronic 1.3
    • · 173 DME-Stock chip 87octane stock injectors
    • · New dme coolant temp sensor
    • · New cluster temp sensor
    • · New crank position sensor
    • · New throttle position sensor
    • · New impulse sensor
    • · New o2 sensor
    • · New alternator
    • · New battery
    • · C101 connector relocated to firewall
    • · Dme o2 and fuel pump relay relocated to firewall
    • · Volt meter added in the car.
    • · 2nd ground strap added
    Misc
    • · Solid motor mounts
    • · Solid trans mounts
    • · No A/c
    • · No Power steering
    • · No Cruise control
    • · No windshield washer fluid
    • · All wiring coming out of the fuse box has been tucked in the fender
    • · E30 m3 wiring covers on the firewall
    • · Early model aux fusebox retrofit
    • · Hid ballast tucked inside the fenders
    • · Oil pressure gauge added
    future
    id like to replace:
    • egr check valve
    • fuel pressure regulator
    • brake booster check valve
    • e30 m3 battery tray wire cover
    I drove down
    they strapped her up
    I installed the coil pick up wire for a tach signal
    ready for the first pull
    results
    128hp
    133 torque
    average of three runs
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • 37829
    I'm not sure that maintenance items count as a mod list.
    My question, what do you mean by port matched gaskets? The gaskets are bigger than the actual ports on the cylinder head. Do you mean that the cylinder head was port matched?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • iwantspeed
      • 3164
      wasn't posting a mod list just whats has been done to it.
      and correct cylinder head ports were matched to the gaskets thanks for correcting that.
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • SpecM
        • Oct 2005
        • 4531
        EGR check valve?
        Sent from my Vortex
        1989 cirrisblau-metallic 325i
        • ForcedFirebird
          • Feb 2007
          • 8300
          Where did he say "mods"?
          Mustang Dyno will read lower than a DynoJet. Numbers look pretty normal for an m20 with mileage, except a little low when removing A/C and P/S.
          john@m20guru.com
          Links:
            The A/F ratio looks a bit wonky. 13:1 would be much better. The shape of the curve (very rich below 4500) makes me suspect that the AFM may be off. But the high end is rich also, which could be a fuel system problem.
            • iwantspeed
              • 3164
              They did not use a air fuel measuring device.
              It's defaulted to 7.3 when it's unplugged
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • LJ851
                • 7918
                ^Why is the left side of the graph labeled "AFR" and scaled to match, then?
                Lorin
                The M30 is God's engine.
                • iwantspeed
                  • 3164
                  I'm pretty sure that's just when they do have the dyno setup for measuring afr
                  Notice at the bottom of the graph that there a flat line at the 7.3 afr ratio and stays flat through out.
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • slippery
                    • Nov 2011
                    • 375
                    Yeah, that looks like torque if you look at the values at the bottom.
                    J
