Schrick Cam ?
  • yrureadingthis
    • 126
    Schrick Cam ?
    I have a mystery performance cam and I don't know who makes it. Are schrick cams labeled in the cast or is there any distinguishing marks on them. Just curious. I thinking about putting it in my 2.3
  • whodwho
    • Jun 2008
    • 1547
    They do:
    What about it make you think it is not stock? that might help identify it.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • yrureadingthis
      • 126
      Cool. Thank you for help. Now it's time to go take a look and what it is. Do most manufactures stamp their cams?
      • yrureadingthis
        • 126
        I noticed when I had to heads sitting side by side. The one head, the valves were farther open then the other. I remember a buddy and me measured both of them and the one cam was noticeably larger. I can't remember how much more it was, but there was a large difference.
        • whodwho
          • Jun 2008
          • 1547
          Others engrave numbers on the end of the cams.
          I would definitely identify it before using it, just throwing a mystery cam in not knowing the specs isn't the best idea. It could be a overly hot cam and totally not be usable and/or give you valve to piston clearance issues.
          • yrureadingthis
            • 126
            I don't think its that hot of a cam. It came out of a automatic 325i.
              • 37834
              If you've got a 2.3L M20 you should just stick with the stock cam.
              Grover Beach, California
              BimmerHeads.com
