What is this down stream from my Fuel Filter??
  • MDVDuber
    • Apr 2011
    • 69
    Hey, Tracking a strong smell of fuel in the car and some hard start and idling issues related to fuel delivery.
    Car is a 1987 325is, so it has the in tank transfer pump and the high pressure pump under the drivers side rear tire.
    I was just checking all my fuel lines for obvious leaks and came across what looks like a FPR in the fuel line just after fuel filter. Here's a picture:
    Since I can't find any reference to it in the Bentley, my first inclination is to remove it and put new line there, cause there is certainly a leak at this device.
    But before I go hacking a slashing I thought I'd ask.
    Thanks in advance for your assistance.
  • jeffnhiscars
    • Jun 2011
    • 6011
    This has come up a couple of times lately. Its a fuel pulse damper & the consensus is you can remove it without consequence. However,if its leaking and you DONT remove it...that has consequence :shock:
    Alice the Time Capsule
    • MDVDuber
      • Apr 2011
      • 69
      Thanks. I looked at the fuel system diagram in the Bentley and it appeared that the damper was in the fuel line AFTER the FPR - which doesn't make sense, but anyhow.
      Ok new fuel line and filter and away she goes.
      Thanks again.
      • jeffnhiscars
        • Jun 2011
        • 6011
        My 84 M10 has it in the engine compartment. They both quack
        • BMW_325i
          • 61
          RealOEM indicates that the Damping Unit is NLA and to be replaced by fuel hose:
          http://www.realoem.com/bmw/showparts...71&hg=16&fg=15
          1988 Lachssilber E30 325i sedan.
          Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
          Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
          Retired - '83 Arctic Blue E28 528i powered by M30B32
          • paperplane94
            • Jul 2011
            • 420
            They quack?
            Like daffy duck?
            • DaButt
              • 476
              I have one in my engine compartment. Never knew exactly what it was... thanks.
              /______\_o_/______\
              l{(OO)=[//][\\]=(OO)}|
              \ #___======___# /
              |__/-------------\__|
              "Took me an hour to do this..."
              took me like three seconds to copy/paste it- FOR SCIENCE!!
              Barney Fucking Rubble
              • jeffnhiscars
                • Jun 2011
                • 6011
                Originally posted by paperplane94
                They quack?
                Like daffy duck?
                you know...looks like a duck, walks like a duck, if it quacks, it must BE a duck...Daffy, Donald or Scrooge McD.
                Your choice
