Intake threw high beam
  • m3/e30fanatic
    • May 2011
    • 2969
    Does this improve airflow a lot? who recommends it and where can i get the kit from?
  • CHIF8008
    • 3447
    like the cone filters sticking out of the car? you can literally just buy a cone and some extra piping to connect them. it not really anything fancy
    i guess that Yes you will get better air flow if it is physically sticking out of the car, but i don't think you are really gonna get any huge gains from it other than noise and some throttle response.
    *if you are gonna run one, but have it sit behind the light hole, then you need a proper heat shield
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • paperplane94
      • Jul 2011
      • 420
      It's silly if you ask me.
      Again, that's if you ask me.
        • 37829
        Honestly a stock airbox is going to give you the best performance.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          • 34839
          the area right in front of the headlight is low pressure. it's not going to do much other than look dumb. there's a slight possibility of colder IATs but that's only a factor if you were running an open cone filter, the stock airbox is just as effective.
          • Mr. Tasty
            • Jul 2011
            • 3421
            through*
            and no, just no.
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • slammin.e28
              שמע ישראל
              • 12054
              If my intake threw my high beam I'd have to put the intake in time out for a bit.
              • Wh33lhop
                • 11705
                Hopefully the high beam is ok.
                paint sucks
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  Could not understand the question until I read it out loud...how could an intake "threw" anything?
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    Probably broke it. You know dem high beams. Fragile things they are.
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      I hate it when my intake does this shit. Last time, this happened:
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • MF DOOM
                        • Apr 2012
                        • 944
                        I pulled a high beam 2 days ago for this reason. Im turbo though. picture later. maybe..
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          This is the only reason I see to remove the high beam. Don't want the turbo to suck it into the intake and mangle shit inside the engine.
                          • MF DOOM
                            • Apr 2012
                            • 944
                            seen it happen. pretty common issue.
                            focoldson.
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              I had mine removed on my e28 for a bit. That was when I was young and less of an asshole.
                              Got tired of people asking me where my light went, why was it broken, and what that hole was for.
                              Seriously though, my high beam did break. I re-installed it and now it doesn't work. -_- I think there's corrosion in the terminals.
