compression ratio help, decked pistons
  • riojin
    • Jun 2010
    • 12
    im in the process of building a turbo 2.7 using a 731 head and 525e 2.7 bottom end. the bottom end has 10.2:1 compression with the 200 head (so the 731 head should be the same).
    i am going to get the standard pistions decked to lower the compression ratio and then ceramic coated.
    i want about 9:1 compression. how much should the pistons be decked in order to lower the compression ratio to 9:1?
  • riojin
    • Jun 2010
    • 12
    anyone?
    • whodwho
      • Jun 2008
      • 1547
      I'm sure there would be people that would trade for lower compression pistons?
      Here is a nice calculator to play with, looks like if you chance the CH of the piston 1.2mm will get it there
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • TobyB
        • 5256
        uhh, you actually should calculate this yourself-
        you have to cc your head, and the dome, then work from there.
        If we give you a number, there's no guarantee it'll work for the head you have.
        What I found with M10's.
        t
