19lb Single Pintle Injectors
  • jules325i
    • Jul 2011
    • 353
    I have a 2.9 Stroker and I'm looking for injectors I'm thinking i should stick to the single pintle.
    Is there a bmw that came out with a 19lb single pintle injectors or where can i get them.
    329i
  • sayed ali
    • 762
    why single pintle?
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
      Why 19lb injectors? If this is a "budget stroker" the stock injectors would be fine. And they would probably be okay for a real stroker. At most you might see a benefit from 17lb injectors.
      • jules325i
        • Jul 2011
        • 353
        2.9l 10.5:1, 272 schrick cam, port polish and other head work , oversized valves. hardly budget.
        329i
        • jules325i
          • Jul 2011
          • 353
          Are m30 injectors to big. i will be running megasquirt.
          329i
          • sayed ali
            • 762
            M30 injectors are fine but they are not single pintle
            M20B28 Turbo
            My Build Thread
            • jules325i
              • Jul 2011
              • 353
              Ok I'm over the single pintle idea.
              so a set of m50 17lb injectors would work.
              How many Bar is the stock 325i FPR, And what resistance am i looking for?
              329i
              • e30leigh
                • Mar 2012
                • 481
                4 bar i believe? they run at about 42psi i know that much.
                • mtech2_touring
                  • Dec 2008
                  • 248
                  I am currently using E36 328i injectors in my 2.9. Pretty much same spec as your motor but 288 schrick
                  • MaksV
                    • 1042
                    Look at my fuel injector thread. I got 17# units and 19# units available.
                    CHEAP REBUILT INJECTORS
                    Need Quality Brakes? BimmerBrakes has it!
                    For anything Else go with BluntTech!
                    • jules325i
                      • Jul 2011
                      • 353
                      Hi, Pm sent.
                      Do you know the resistance of stock 325i injectors.
                      329i
                      • jules325i
                        • Jul 2011
                        • 353
                        Do you think i will see any performance increase from stock 14lb to 19lb injectors.
                        329i
                        • digger
                          • Nov 2005
                          • 6207
                          just get some 19lb or there abouts
                          • jules325i
                            • Jul 2011
                            • 353
                            Ive ordered Ford Mustang 19lb.
                            329i
                            • dnguyen1963
                              • Nov 2011
                              • 2651
                              Be prepared for some rough idle at low rpm if you are using 19# with stock chip.
