i have a 325i.
it has a din an chip and m50 injectors installed, ran fine after installed no problems. running on premium
one day, i went to drive it up the block. and when i got on it, it would choke, backfire, then continue to pull, and some times it would misfire at lower rpms,
the idle is also crazy going up to 2k, then down, however this would eventually go away after warming up.
sometimes it would begin to idle normal, then it would just stall out after a couple of minutes.
i assumed it had a bad coil, due to the choking out. replaced the coil and it started right up, idle was still a little wacky. then it began to warm up (about 1/4 of the gauge) and the idle settled, then i heard it want to stall out, save its self, then idle, then eventually it just stalled out.
after that i went to start it and now it just cranks.
the car currently is throwing a 1444 code (no errors)
but in the past it has thrown a coolant temp sensor code, and an o2 sensor code. both i know relate to the controlling fuel mixture and what not through the ecu.
throw ideas at me.
PICS OF SAID CAR....
throw ideas at me.
