Background
I am rebuilding an m20b25 with custom forged Ross Racing Pistons and an s52 crank. The engine with have a total displacement of 2979 cc and I am trying to determine the necessary steps to get this running properly.
Problem
With a larger displacement comes more air flow into the intake and that requires more fuel. Some say the stock fuel injectors are almost at full duty cycle as it is in a regular m20b25. Others also say the air flow meter is a large restriction in the system. With a 20% increase in displacement one would need to consider an increase of the same amount of air and fuel into the system.
Questions
1. I have heard fuel atomizes better at higher fuel pressures. I also have an adjustable fuel pressure regulator, 24 pound injectors as well as an eta fuel pressure regulator (2.5 bar vs 3.0 for i motors). What would be a better setup, stock injectors with a higher fuel pressure (~20% higher) or 24# injectors with eta FPR? Some other combination with Adjustable FPR?
2. Will the m30 AFM help anything or should I not bother? Will a MAF better suit my needs, and where do I get one?
Obviously this is a rough estimate and will need some tuning of the AFM and wideband to help with the fine tuning.
PS: I would like to start the engine on the motronic 1.0 that is in the car (m20b25 euro early model), please don't suggest megasquirt off the bat as I need to find an eta connector to take apart if I choose that route, or wire a board like this.
http://www.hpheaven.com.au/store/parts-accessories/info/1394/wolf-35-pin-bosch-motronic-connector/?cat1=1&catid=0&page=1
I'm not even sure that board has all the connections I need.
Problem
Questions
