Broke a rocker Easiest way to fix? (pics inside)
  • bmk
    • Feb 2011
    • 598
    I took off my valve cover to inspect what I thought was gonna be a bent valve and I find that one of my rockers sheered in half. Can anyone tell me what is the easiest way to go about fixing this?
    Worlds 1st LS powered e30 cabby.
    Cab
    billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
    Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
    Shaggin Wagon
    : 01 325xiT 5 speed
    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
    88 CRX OEM+ 42mpg DD.
  • gtdragon980
    • Jun 2008
    • 1808
    You'll have to pull the head unless you have a engine hoist. Then you can lift the engine up just enough so you can slide the rocker shafts out enough to replace it. The radiator and a/c components are in the way to pull the shafts out far enough if you don't raise the engine up.
    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
    Originally posted by scabzzzz
    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
    1989 325i - Project/weekend driver
    2002 325i - DD
    2005 Suzuki SV650 - Toy
      Yep, what he said. There is no easy way to fix that one. Even with hoist you may destroy the rocker shaft trying to get out since you can't drive the shaft from the other end. My advice is that you pull the head and rebuild it. One broken rocker means that others are likely to break, so you should replace all of them. I'd also have the valves ground and a minimal surfacing cut done on the head.
      While high rpm operation increases the chances of a broken rocker, I've seen them fail on cars with automatic transmissions that seldom, if ever saw, the territory north of 5k. An the can fail on ETA engine with the 5400rpm limit. My theory is that a history of a lack of timely valve adjustments is the primary cause. The repetitive impacts from loose valves cause cracks to form.
      • bmk
        • Feb 2011
        • 598
        Thats exactly when mine broke, doing a high rpm pull...boo
        Cab
        Shaggin Wagon
        : 01 325xiT 5 speed
        • bmk
          • Feb 2011
          • 598
          I have an engine hoist so that is no problem. Would you recommend taking out the drive shaft to get the most amount of raise. (taking out the ac/radiator is no problem ive replaced several m20's over the years)
          Cab
          Shaggin Wagon
          : 01 325xiT 5 speed
          • plmichal
            • 718
            From personal experience.
            I broke one rocker arm a few months ago and replaced it. A few weeks later, I was beating on my car again and snap goes another one. Just rebuild the head or buy one rebuilt. Much less hassle.
            1990 325is Brilliantrot/Natur
              Yep, when you break one, you will soon break another, and so on. Bite the bullet and rebuild the head.
              Oh yeah, on a car that will frequently see the top of the rpm band, polishing the area of the rockers around the eccentric removes stress risers and reduces the chance of cracking. That and adjusting the valves every 10k should eliminate any future problems.
              • e30leigh
                • Mar 2012
                • 481
                its shame. but its the truth. where theres smoke theres fire.... its just a matter of time till another fails now sadly.
                but if you take out the rad, ac and front grill you can also get them out without lifting the motor. but its a real pain in the ass. you might as well take off the head. the work involved is about the same. good time to head stud it as well.
                • TobyB
                  • 5287
                  I'd add new valve springs to the list of things to refresh while you're in there...
                  ... after loose lash, that's a major cause of high- rpm failure.
                  t
                  • CHIF8008
                    • 3447
                    & valve keepers! never freaking re-use valve keepers. no need to drop a valve because you didn't want to buy "one more thing".
                    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                    -The Beauty in the Tragedy-
                    MECHANIC SMASH!!- (you all know you do it)
                    Got Drop?? ;-)
                    But of course
                    E30s are know to be notoriously really really really ridiculously good looking
                    • gtdragon980
                      • Jun 2008
                      • 1808
                      Personally, it would be more work to remove the driveshaft and what not to tilt the engine enough to replace 2 rockers. If you have the money, and want your car to be as reliable as possible, take the others advice and rebuild the head. And even if you choose not to, you can still remove the head, replace the broken rockers and replace the head gasket as it may not need it now but later on down the road it may.
                      Forgot to add, but I had two break on me once, but there were in the back of the head so I just replaced the two. Plus my engine has really low mileage so I think it was caused because of abuse, not wear and tear. In your case, if you have high mileage, just spend the money now and fix her all up!
                      2002 325i - DD
                      • Maloney
                        • Jul 2012
                        • 49
                        does this go for all valve keepers??
                        I thought the same thing man. But i have had my 1jz head taken apart and put back together, and ran again several times with reusing factory valve keeps and the machine shop never said a word or suggested that i get new ones....
                        and i was glad, expensive little fucks they are!
                        • bmk
                          • Feb 2011
                          • 598
                          The motor was rebuilt somewhat recently, or so i was told. SO if i was going to replace just the rocker what parts would I need besides the rockers and HG?
                          Cab
                          Shaggin Wagon
                          : 01 325xiT 5 speed
                          • bmk
                            • Feb 2011
                            • 598
                            bump
                            Cab
                            Shaggin Wagon
                            : 01 325xiT 5 speed
                              You will absolutely need head bolts, a timing belt/tensioner, valve cover gasket & bungs, exhaust header gaskets and new copper plated nuts, and oil return tube o-rings. While the head can be removed and installed with the intake and exhaust headers attached, that is really a two person or hoist job. If you remove the intake and exhaust you will also need gaskets and new copper plated nuts for the headers. It would be a good idea to also replace the cam seal and o-ring.
