SNAPPED MAIN BOLT HELP ME ! M20 help pics up
  • e30m20TurbO7
    • 1203
    hi i snapped one of the bolts while trying to torque the main caps
    number 7 cap bolt snapped
    posting pics right now
    pleas help need help asap
  • e30m20TurbO7
    • 1203
    the first pic is of a hole with out a bolt in it
    the second one is the picture with the bolt in it for comparison
    • e30m20TurbO7
      • 1203
      • Cletonius
        • 2809
        Try a left hand drill bit?
        - Josh
        1990 325is
        Need a shift boot?
        Looking to buy shift boot frames, PM if you have one to sell
        Here's what happens when you let the internet pick your license plate
        • SmokeE30
          • 1730
          yea left hand drill bit would be your best bet, nothings going to make that easy though, i personaly would just find another block as you already appear to have it all torn down that would be the easiest route
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
          • paperplane94
            • Jul 2011
            • 420
            When you drill a hole in the bolt for the left hand bit, make sure the hole is EXACTLY in the center of the bolt.
              Your best bet is to make a guide bushing to drop into the hole and try a left hand twist drill.
              • paperplane94
                • Jul 2011
                • 420
                Please elaborate on the guide bushing technique.
                Broken bolts happen are bound to happen to all of us.
                • e30m20TurbO7
                  • 1203
                  New block would have been a bitch
                  Thanks for your guys help
                  Anyone got the correct torque specs for the main caps
                  • Aluke123
                    • Aug 2011
                    • 76
                    The Bently says it's like 14.5ft/lbs + 70 degrees. I did mine a few months ago.
                    • FLG
                      • Sep 2011
                      • 3165
                      Just some info for future ref...done it tons of times on exhaust manifold bolts that snapped.
                      Break out a welder and weld a nut to the bolt, grab a socket or wrench and it'll come right out, weld dosnt stick to the cast.
                      Sent from my Galaxy Nexus using Tapatalk 2
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                      • tinkerputzer
                        • Jun 2008
                        • 508
                        That is rod bolt torque spec. Mains are 45 ft/lb. You should really have this info available to you if you are building a motor.
