I've been (slowly) gathering up what I need to swap out the engine in my '86 eta for an '89 325i engine. I'm now under a deadline, and I need to have this project completed inside two weeks. Both cars are automatics, and I'll be swapping out the transmissions as well, since the i spec car had a lot fewer miles on it, and my daughter's '84 eta needs the flex plate (flywheel) for her car. For some reason, she doesn't like that screeching sound when the starter gear finds that bare spot on the ring gear.
The parts I have gathered for the task, many from an '89 325i donor car:
engine harness
AFM
DME
7000 rpm tach (along with the rest of the cluster)
I'm looking for an i-spec coding plug for the tach.
Am I missing anything?
engine harness
AFM
DME
