I'm about 2 weeks away from swapping my motor and I didn't think of this before but do I need to use a drive shaft from an m20? I'm using the same transmission from my m42 but will the m20 push the driveshaft back?
Swapping a m20 into my 318is, help!
Tags: None -
im prety sure the G240 will NOT bolt up to the m20.
u need a g260, and a its matching driveshaft.1989 325i SETA stroker [delphin] R3V'd 8/31/2011
1989 325ix [zinnoberrot] $OLD
1970 2002 [Nevada]
Originally posted by Herr Faust Schinkenguy must have slid into something that doesn't look like a car vs car hitOriginally posted by ak-Must of slid into RobComment
2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
Sorry for off topic but I'm looking at a 318 that a guy swapped an m20 into. One issue is the tpsensor in the radiator is bad. How complicated is this swap? Does it require nasty wiring changes?Comment
I just picked up a 260 with driveshaft, I'm doing and m20 swap because I have an m20 with 59k on it. I also have everything to turbo that m20 and a megasquirt setup for this same motor. My m42 has 193k on it and I would rather boost a motor that can handel it than this m42 with 21 years of bouncing rev limiter, so I don't believe it's a stupid swap.Comment
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
